Vibration under load?
208,000 MILES • V6 • 2WD • AUTOMATIC
BHAMDOC1973
  • 2,007 POSTS
How can you tell if a vibration under load especially felt going up on an incline is due to axle or a bent wheel, starts at low speeds but goes away once you are on the highway.
Aug 24, 2023 at 8:57 AM
  • 110,248 POSTS
If you have a bent wheel, it will likely be felt at all times and not just under a load.
As far as the axle, a failing CV joint can do this. Check to make sure none of the rubber boots over the joints are damaged and leaking grease. Also, in a safe area, from a start, turn the steering wheel fully and slowly accelerate. Oftentimes, a failing joint will make a clicking noise. Here is a link you may find of interest. It reviews the most common symptoms related to a failing joint. See if anything mirrors what you experience.
https://www.2carpros.com/articles/symptoms-of-a-bad-cv-axle-joint
Aug 24, 2023 at 1:52 PM
BHAMDOC1973
  • 2,007 POSTS
Okay, I will check all that. Also, it's not in the steering but in the floor, and changes intensity from if steering is straight on highway, yes if am going over a curve which makes it worse.
Aug 24, 2023 at 9:48 PM
  • 110,248 POSTS
Okay, if you feel it more in the floor, then chances are it is one of the rear wheels. It could be a wheel bearing. Lift one rear wheel off the ground at a time. Check to see if there is play in the bearing or if there are any broken components.
Place your hands at 3 and 9 o'clock and wiggle back and forth to check. Do the same by placing your hands at 6 and 12 o'clock.
Take a look at this link, it explains common symptoms related to a failing wheel/hub bearing:
https://www.2carpros.com/articles/7-common-symptoms-of-a-bad-automotive-bearing-hub
Aug 25, 2023 at 12:37 PM
