vibration in gear even more when ac on
132,109 MILES
ALDUNN
vibration in in drive and rev. and slightly in neutral and very high vibrations with the ac on.It calms down a little after driving for about 20 mins. and neutral seems to stop. I cleaned the thottle body, oem mounts incl.the trans,plugs(boche double plat),fuel filter,and basic oil change.I seem to hear a air/fluid build up when starting and when shuting off i hear a shoosh air release sound;and if helps when starting somes times its one big booming then sometimes its smooth as day one and then the slightly delay
Aug 11, 2013 at 11:02 AM
  • 110,251 POSTS
If you are getting a vibration that goes away in neutral, have you checked the motor and trans mounts to make sure they haven't collapsed? If the rubber on them is bad, you will feel a vibration from the engine.
Aug 11, 2013 at 2:07 PM
