Engine bay is clean, i checked engine mounts and they don't feel like they are moving and i don't feel a jerk when i hit gas and brake to check them. But inside the cabin there is a vibration that is worse when the car is cold. Vibration does not change if it's in neutral park or gear, and transmission shifts like it should so i know it isn't the torque convertor. Once you drive of course you don't feel anything, only when idling. You probably won't hear or see anything in the video but no change in the vibration with shifting gears.
Dec 20, 2021 at 7:16 AM
