vibration from rear wheels / axle when accelerating
174,000 MILES • 6 CYL • RWD • AUTOMATIC
VIT75
When accelerating at a normal rate, and whether the car is in automatic or sport shift (manual) mode, I get a vibration (feels like from right rear more than left) which feels and sounds like going over a rumble strip between the speeds of twenty to thirty mph and most noticeable in second gear. I have had tires balanced and rotated and vibration still stayed in the right rear area.
Jul 15, 2016 at 5:17 PM
WRENCHTECH
  • 20,760 POSTS
If you feel it mainly only when accelerating, it could be a bad inner C/V joint that is binding.
Jul 15, 2016 at 8:30 PM
VIT75
Would it be best to replace or continue to drive until it gets worse? Expensive repair?
Jul 15, 2016 at 11:49 PM
WRENCHTECH
  • 20,760 POSTS
I would replace it as soon as you can confirm that is actually the problem and you will need some local talent to do that.
Jul 15, 2016 at 11:52 PM
VIT75
Thanks, have relocated and still looking for good mechanics, that is why I was asking before I go in to see if they come up with same remedy/cure as you. Again, thanks for sharing your knowledge, greatly appreciated.
Jul 16, 2016 at 12:07 AM
WRENCHTECH
  • 20,760 POSTS
The person that actually drives the car has a big advantage in diagnosing it correctly.
Jul 16, 2016 at 12:08 AM
