vibration during a certain speed
69,000 MILES • 2.5L • V6 • RWD • AUTOMATIC
KARL00
This vibration only happens occasionally and usually at around fifty km/h and seventy five km/h.When accelerate hard the vibration goes away. Only happen when gently accelerate and when reach speed around fifty to seventy five km/h the vibration comes on.
Letting go the accelerator the vibration goes away.
And yes there is a check engine light ( code p0031 ).
Is it possible that this is related to the code?
And I notice that when accelerating full from a stand still, it seems to hesitate shifting in to the second gear.
I than put it in "N" and back to drive before it shifts up.
Sep 21, 2017 at 1:18 PM
  • 55,694 POSTS
Tire problems come to mind for me like the tires are not balanced or one of them has a defect. Can you try to rotate the tires front o back to see if that helps?
https://www.2carpros.com/articles/how-car-tires-work
The code is an oxygen sensor that has gone out and needs to be replaced. Bank 1 sensor 1
https://www.2carpros.com/articles/how-to-replace-an-oxygen-sensor
Cheers, Ken
Sep 23, 2017 at 7:09 AM
