Vibration between forty to sixty mph
100,000 MILES • 2.4L • 4 CYL • 2WD • AUTOMATIC
MOHSINAARFI2002
Hi
I am observing vibration when I am giving the accelerator gently and speed between forty to sixty mph and it is gone when I press the accelerator hard or speed limit above sixty mph. what is the reason for this ? I heard so many stories on this I seriously need help . Thanks
Dec 1, 2017 at 6:38 AM
KHLOW2008
  • 41,812 POSTS
Hi MOHSINAARFI2002,
Such symptoms indicates a fault with the driveshaft inner joints. When the inner joints lacks lubricants, it will be unbalanced and while driving would produce the symptoms indicated.
Check the inner CV boots condition and note if grease is splashed around surrounding area. Repair as necessary.
Dec 1, 2017 at 9:36 AM
