vibration
107,000 MILES
RCEIERMANN
I have a vibration in the rear of the car that is non-existant on a straightaway; yet in a left turn there is a significant vibration. I have replaced the rear axel bearing on the right side, and had a new driveshaft manufactured to the tune of $500. The car drives smoother, but the vibration is still there. I have no idea what the problem is.
I want to fix it before I find out what the problem is on the side of the road.
Thank you,
Robert e
Apr 21, 2013 at 4:35 AM
make sure all the bushings are good with the control arms and stabalisers in the rear mountings/
Apr 21, 2013 at 5:00 AM
RCEIERMANN
I'll check them out. They should be fine, they're only 3 years old, with maybe 5-600 miles on them. I don't have a lot of confidence in the individual that replaced the bushings in the trailing arms, so I'll start there.
Thank you
Apr 21, 2013 at 6:09 AM
