Vibration when idling in neutral?
200,650 MILES • 4.6L • V8 • 2WD • AUTOMATIC
WOLFSHEPHERD
  • 9 POSTS
Slight vibration when idling in neutral, more heavier when in drive or reverse. Sometimes slight, other times more intense--intensity is intermittent.
I'm not delusional, it's close to a 30 years old. I've owned it for 9 years and put 120k on it myself and am fanatical OCD when it comes to its care and maintenance. The engine is very strong--smooth running. Very recent plug replacement, old plugs showed no oil burn, though thought they looked a little lean.
Smoke tested -- negative leaks
Standard motor mount test indicates mounts are good, though, honestly, I can't but think it's the mounts (hydraulic) even though they passed the rev-on-brake test.
Recent fuel pump replaced.
Recent (1 year) harmonic balancer replaced
Power steering pump solid (relatively new), not a whisper of noise, no issues.
Very recent belt pully and belt tensioner replaced.
A lotta smart people scratching their heads.
Though have yet to get a full OBD2 diagnostic scan.
Ideas?
Apr 2, 2026 at 9:41 AM
  • 55,649 POSTS
Yep, that is what I would do first, lets run the codes to see if any are present. This video will help.
https://www.youtube.com/watch?v=LBCpCWEFnTg
Please go over this guide and get back to us. Also, if you can upload a short video of the engine idling it will help us see what is going on. Ken
Apr 3, 2026 at 1:25 AM
WOLFSHEPHERD
  • 9 POSTS
Right. Though not throwing a check engine light.And as I said, I'm not delusional, I just turned 200k miles on it. And until recently was purring like a cat and running like a cheetah. No loss in power, still pulling 25-27 mpg on freeway. Shifts smooth as it should. Im an otr truck driver, so will be a few days before I could make video.
Apr 3, 2026 at 3:18 AM
  • 55,649 POSTS
No problem, if the milage is okay then then engine sounds good. Could it be like a exhaust system rattle?
Apr 4, 2026 at 1:26 AM
WOLFSHEPHERD
  • 9 POSTS
No. Nothing like that. And exhaust is solid since I just replaced a busted bracket. All indications point toward mounts. But standard brake-rev test shows no excess movement.
Apr 4, 2026 at 1:35 PM
  • 55,649 POSTS
The engine mounts can still be collapsed. Have you checked the transmission mount?
Apr 6, 2026 at 1:34 AM
WOLFSHEPHERD
  • 9 POSTS
A shop did and said all looked good.though if I do motor mounts, solid rubber vs, hydraulic, I'd do the tranny mounts, too. Has polyurethane now, but have rubber mount I'd put on.
Apr 6, 2026 at 3:56 AM
  • 55,649 POSTS
Polyurethane? like race car mounts? I have only seen rubber mounts.
Apr 7, 2026 at 3:11 AM
WOLFSHEPHERD
  • 9 POSTS
Oh, just the tranny mount.
Apr 7, 2026 at 5:13 AM
  • 55,649 POSTS
If the engine is running smoothly then replace the engine mounts with rubber.
Apr 8, 2026 at 2:24 AM
