Vibration in steering wheel?
200,000 MILES • 3.5L • V6 • 2WD • AUTOMATIC
XANDYB
I have not been in my car for 2 days. I go to get into it this morning and before putting the key into the ignition I noticed my steering wheel was vibrating and there was a noise coming from behind the dash as if there was a motor running. I just had my transmission rebuilt a month ago. Not sure if that would have anything to do with it. I have also noticed that when I'm driving, upon acceleration my car would bog down sometimes. Like really bog down. What could these problems be? I just changed my engine filter last week hoping that would help the bog down, but no. It did not.
Apr 15, 2023 at 12:49 PM
  • 55,721 POSTS
These are two different problems can you please start a new question for the engine bog problem? For the steering problem please check the power steering fluid level and condition. I have seen worn out fluid cause this problem which means the system needs to be flushed out.
Here is a guide to help walk you through the steps:
https://www.2carpros.com/articles/power-steering-fluid-flush
Please go over this guide and report back. Can you please shoot a quick video with your phone so I can hear the noise? That way I can tell for sure what's going on. You can upload it here with your response.
Apr 17, 2023 at 3:31 AM
