My car start to vibrate at sixty two mph. Got wheel balanced but problem still found .
Jul 22, 2018 at 6:33 PM
✓Experienced Mechanic
Hi there, just a bit more information on this problem, is the vibration in the steering or the body? As if in the steering it will be front wheel related and if in the body it will be rear wheel related.
Jul 22, 2018 at 7:10 PM
KHALIDDVD
MEMBER
What do you mean steering or body? I feel all car body shaking and vibrate (right to left quickly) when reach 100 km/hr and above.
Jul 27, 2018 at 6:08 AM
If the vibration is felt in the body, and the steering wheel is not particularly affected that is it is not shaking in your hands the problem will be rear wheels or rear suspension related. If the steering wheel is shaking in your hands it will be a problem with the front wheels or steering components. If you can advise where you feel the vibration is felt we can work on narrowing down the problem.
Jul 30, 2018 at 5:05 PM
KHALIDDVD
MEMBER
I feel my car vibrate and shaking very hard after 100 km/hour from right to left. I got tires balanced but still the same problem.
Sep 13, 2018 at 9:55 AM
(Merged)
Good morning.
I would have the tires rechecked for shifted belts. You can also verify by rotating the tires to the rear and see if it stops shaking the wheel.
Have the suspension checked as well. It could be loose or broken causing play in the front end.
Re check rear tires for out of balance and rim buckle. This is often the problem, also make sure the rear suspension is serviceable as well. If you have any problems checking anything post back for more advice.
