vibration
150,000 MILES
DAN CALDER
I have a 1946 Chevrolet on a s10 frame. new fly wheel/new balanced drive shaft. separated torque converter. still have bad vibration in truck. even in park.
Aug 2, 2016 at 12:06 PM
HMAC300
  • 48,601 POSTS
what engine? it may be the wrong converter or balancer is broke or something wrong with engine.
Aug 3, 2016 at 12:16 AM
DAN CALDER
It is a 2.8. do you the harmonic balancer on the front. how do they go wrong?
Aug 3, 2016 at 12:59 AM
HMAC300
  • 48,601 POSTS
if it does it in park then it may be the torque converter is the problem you can check a balancer by marking it at #1 then start the car give it a quick rev then bring it back to #1 if the mark has moved the balancer rubber may have broken. Or it could be the flywheel/flexplate is the wrong one.
Aug 3, 2016 at 1:18 AM
HMAC300
  • 48,601 POSTS
also check for misfire or wrong firing order and engine/transmission mounts as well.
Aug 3, 2016 at 1:19 AM
