vibration
156,000 MILES • 4.0L • 6 CYL • RWD • AUTOMATIC
ARSUWANSKI
at speeds between 15 and 25 car will vibrate when i let off gas and then push pedal down and give it gas again it goes away i have changed rear seal and replaced transmission under mount still happens and now i hear a slight pitch sound
Feb 9, 2016 at 4:08 AM
JOHNNYT73
  • 924 POSTS
I think they use a two piece driveshaft? check the center bearing at the driveshaft. The bearing in it may have failed.
Feb 9, 2016 at 4:35 AM
ARSUWANSKI
that is what i was thinking is it possible that it may be a transmission issue
Feb 9, 2016 at 4:43 AM
JOHNNYT73
  • 924 POSTS
I wouldn't assume that right away
Feb 9, 2016 at 4:47 AM
ARSUWANSKI
ok thanks i will try that
Feb 9, 2016 at 4:48 AM
HMAC300
  • 48,601 POSTS
scan fro codes and check fuel pressure with a gauge as well.....autoparts rent it.
Feb 9, 2016 at 7:09 AM
