Vibration
156,000 MILES • 1.7L • 4 CYL • 2WD • AUTOMATIC
ALEX19899
  • 171 POSTS
Hello, my car is currently in the shop getting the head gasket replace and resurfaced and timing belt and water pump. But my question is my car vibrates a lot like it vibrates the whole car. I already replaced the engine mounts and spark plugs. The mechanic said coolant was getting into the cylinder heads that was causing a misfire. How true do you think that is?
Jan 8, 2019 at 12:36 PM
DANNY L
  • 5,648 POSTS
Hello, I'm Danny.
Yes, a leaking head gasket will cause coolant to be burned during the engines combustion process.Having a misfire can also cause a vibration as well.Here is a tutorial showing what is involved:
Hope this helps and thanks for using 2CarPros.
Danny-
Jan 8, 2019 at 3:43 PM
