There is a problem with coolant temperature. When the engine is running, but do not drive the coolant the temperature is rising, but it does not reach normal value. But when the car is driving the coolant temperature drops to minimum. The air temperature is now about 20 degrees Celsius (about 70F). I replaced the thermostat from other car (it was used part, I do not know if it was 100% okay, but I think so), but it is again minimum temperature.
What is faulty? What should I check, replace?
Is there any sensor which controls the temperature too?
This car was after a car accident. There was whole engine with radiators replaced.
I am waiting for your help.
Best regards,
Pawel
Best regards,
Pawel
Oct 3, 2023 at 10:13 PM
