Very hard to start?
125,000 MILES • 3.6L • 6 CYL • AUTOMATIC
RUDYBREWER
The car runs great, then I stop to fuel up and after fueling I have to crank it for quite a long time for it to start again. After the initial start, it will start very quickly and easily, until the next tome I need gas. Was told not to fill it each time. Tried that and no matter how much or little I put in, it is the same.
May 14, 2015 at 3:25 PM
SATURNTECH9
  • 30,868 POSTS
I have seen where the vent control solenoid sticks on causing too much vacuum to enter the tank you can take it to have the codes done or do them yourself by following this guide.
Cheers
May 14, 2015 at 11:29 PM
RUDYBREWER
No, I was hoping to avoid the cost. Because it is such a specific problem, I thought maybe someone else had experienced it. I cannot let go of the key fast enough until I stop to fuel. Then, only on the initial startup, I have to crank anywhere from 20-40 seconds (or more) before it starts. After starting, the 1st few seconds, it sounds like an old carburator car that is flooded. It takes a few seconds to"clean out". Then it will start and run perfectly until the next gas stop where the whole process repeats itself.
I ordered a scanner today, Thanks.
May 15, 2015 at 12:01 AM
SATURNTECH9
  • 30,868 POSTS
Usually when i hear a concern like that i think the vent solenoid system.If you dont live in California you can get your codes read for free at the auto parts store.At some point it might not start after a fill up.
May 15, 2015 at 5:47 AM
RUDYBREWER
Hello, I just got checked. Have two codes, PO442 & PO496 both dealing with Evap emission. Not sure why my next step is now. Was told I have to now go through diagnostics test to find out.
May 28, 2015 at 4:26 AM
SATURNTECH9
  • 30,868 POSTS
For the p0496 there has been tons of canister purge solenoids bad setting that code.With the canister purge solenoid unplugged i would see if you can blow thru it?They stick open allowing vacuum to always be flowing to the gas tank.That could explain the car hard to start after filling the tank.
May 28, 2015 at 12:02 PM
TAYLOR ELIZABETH
But what if your car is doing these things but isn’t giving you any codes????
Sep 9, 2020 at 12:01 PM
Good morning,
Do you have the same codes set as this question is addressing? If it is hard starting after fueling, that could be the purge valve for the system that was addressed in one of the answers.
Codes will cover fuel control failures, not mechanical.
What are your symptoms? I attached the procedure for the purge valve and some pictures for you to view.
Evaporative Emission Canister Purge Solenoid Valve Replacement
Removal Procedure
1. Remove the fuel injector sight shield.
2. Disconnect the chassis EVAP pipe (3) quick connect fitting from the EVAP purge solenoid.
3. Disconnect the EVAP emission canister tube quick connect fitting (2) from the EVAP purge solenoid.
4. Disconnect the engine wiring harness electrical connector (2) from the evaporative emission (EVAP) purge solenoid.
5. Remove the EVAP purge solenoid bracket bolt.
6. Remove the EVAP purge solenoid.
Nov 25, 2020 at 12:24 AM
This is a pretty common thing when the EVAP (emissions) system has raw fuel in it. This system is only supposed to pull the vapor out of the tank and use it in the engine so that it is not released to the atmosphere. However, when this system gets raw fuel in it, the charcoal in the charcoal canister will breakdown and will clog the purge solenoid. This will cause it to stick open and allow too much vapor into the engine causing a hard start after filling the tank because it is pushing more vapor into this system.
I am attaching the process to replace both the purge valve and the canister as I suspect both are failed at this point. This is for the vehicle listed on this post. If you have a different vehicle then let's get a new post started and we can get the process for your specific vehicle.
Let us know if you have other questions. Thanks
Nov 25, 2020 at 12:29 AM
