very black smock with black powder, poor acceleration, AC on Car RPM drop down sudden and car stops
20 MILES • TURBO • FWD • MANUAL
DENNRY0
  • 8 POSTS
My ford fiesta is in trouble. Fallen down the speed and not getting power as i accelerate.
and black smoke and black powder .. usually when pressing hard on accelerator and starting time.
I have checked on computer it was giving MAF sensor error but when i check MAF it was giving good readings. Now mechanic told me that we should change MAF but I am not sure about it that it will work good enough after changing MAF.
My car has driven 1,03,000 Km.
What should I do..?
my car was once overheated but I noticed and stopped at that time. and after that I clear that issue soon.
Is overheating nearly @ 120 Celsius for lil time….!!
Car is starting and working ..but no power ..mean no turbo pick up.. and black smock / and black powder comes from exhaust when I press hard on accelerator.
EGR pipe inspected with too much carbon. and i cleaned. then no error of EGR for while..
After sometime again EGR problem seen. should i clean it or replace it??
MAF sensor changed but still poor acceleration.
Turbo checked and its working fine as ford technician said.
No other engine voice as technician said.
please help..!!
Nov 21, 2015 at 2:41 AM
HMAC300
  • 48,601 POSTS
check fuel pressure with a gauge in U.S. auto parts rent it. scan for codes it may be a wire bad at maf shorting out. also check for blockages and no air leaks in duct work leading from maf to engine.
Nov 21, 2015 at 3:05 AM
DENNRY0
  • 8 POSTS
Thanks for reply..!!
I have checked for wires it is ok.. Also I have cleaned all connectors..!!
MAF to engine ...No air leaks.
I will check for fuel pressure as u said..!!
should i change engine oil and oil filter as car driven over 6500 miles
And there was too much carbon found in EGR and EGR pipe was also much jammed. I cleaned but again after some drive with all dark black smock powder it is showing some problem in EGR.
Thanks..!
Nov 21, 2015 at 1:54 PM
HMAC300
  • 48,601 POSTS
get the code to see what it is it may be a vacuum or electrical problem besides clogged passageways or pintle on egr.
Nov 22, 2015 at 7:42 AM
DENNRY0
  • 8 POSTS
Thanks For reply but Still there is a same problem..!!
Even ford technician couldn't tell me exact problem they said that replace MAF and EGR valve and then problem persist we will go to engine.. :(
can it be engine problem ?
Nov 23, 2015 at 1:46 PM
HMAC300
  • 48,601 POSTS
scan for codes and check fuel pressure with a gauge first
Nov 23, 2015 at 11:18 PM
DENNRY0
  • 8 POSTS
Now Car is not starting..!!
Engine is not getting compression technician said .... !!! :::(((
Nov 26, 2015 at 3:42 PM
DENNRY0
  • 8 POSTS
Thanks for your help..!!
I have decided to sell it now..!!
Nov 26, 2015 at 3:43 PM
DENNRY0
  • 8 POSTS
They told me not any issue with fuel gauge..!!
Engine is not getting compression..!!
There is work in the engine..!!
What should I do..?
Should I sell..?
As they told me a huge estimate expense ?
Nov 26, 2015 at 5:24 PM
HMAC300
  • 48,601 POSTS
look at it this way if it has low compression you need to find out the cause if it's valves then it will be cheaper to fix. If you have the car paid for then see what a replacement will cost vs fixing your current vehicle.
Nov 26, 2015 at 11:22 PM
DENNRY0
  • 8 POSTS
Thanks..!! I will see..!!
can you give some more details ..!?? how to check it ?
Nov 27, 2015 at 1:31 AM
HMAC300
  • 48,601 POSTS
check compression
Nov 27, 2015 at 1:54 AM
DENNRY0
  • 8 POSTS
ok..
Nov 27, 2015 at 1:57 AM
