Very bad fuel consumption
180,000 MILES • 3.5L • 6 CYL • 2WD • MANUAL
BUDDIE95
  • 5 POSTS
Hi all, I have the vehicle listed above (RA) with motor and 5 speed manual transmission. I have owned this vehicle for about 2 years and for the entire time it has had very bad fuel consumption i.e. 6km to the liter or worse.
The vehicle has had new plugs, air filter, fuel filter, the MAF sensor has been cleaned and there are no vacuum leaks that I can find. All the grounds have been checked cleaned and tightened and it has been on several diagnostic machines with no errors found except that sometimes it's reported that the left rail has high pressure.
The vehicle also occasionally cuts out after hunting when you stop at a red light or stop sign etc.
Can anyone suggest how I can improve the fuel consumption?
To put it into perspective - it has a 76 litre fuel tank and I can't get 400 km out of it unless I'm on the highway.
Thanks in advance for any help you can provide.
Feb 16, 2021 at 8:28 PM
  • 110,248 POSTS
This is a tough one. You have replaced most all common causes. However, have you check to see if you have any brakes hanging up and causing a drag on the vehicle?
As far as the fuel pressure, I would recommend checking to make sure it isn't too high. Here is a link that shows in general how it is done. You will need a fuel pressure gauge, but most parts stores will lend one to you.
Take care and God Bless,
Feb 18, 2021 at 10:13 AM
