Vents stay open
215,000 MILES • 6.0L • V8 • 4WD • AUTOMATIC
BMCFIELD
My vents will not closed even when switch is closed. Can't blend temperatures. Either hot or cold, not warm. Controls will not change to different location like defrost.
May 14, 2019 at 1:33 AM
  • 55,711 POSTS
It sounds like you have two blend door actuators that are bad can you hear any noises? Here is a guide to help you change the actuators out:
May 15, 2019 at 3:46 AM
BMCFIELD
No noise. Vents just stay open when on cold or hot.
May 15, 2019 at 11:29 AM
  • 55,711 POSTS
When you move the control can you hear any vent door moving?
May 16, 2019 at 4:29 AM
