Vents stuck in defrost
253,000 MILES • 7.3L • V8 • TURBO • 4WD • AUTOMATIC
GARRETT CRAWFORD
Bought a truck with vents stuck in defrost. I can turn dial to any position, even max AC and still stuck on defrost. With that case how do I fix the issue? Also, does the AC turn on when vents are in the AC position? I have turned dial to AC and max AC to see if I can get cold air out of defrost vents. Does not seem to kick on AC.
Jul 18, 2017 at 4:41 PM
  • 55,837 POSTS
Please Check the vacuum lines headed into the firewall which run the defroster and heater. Here is a guide that should help you get the problem fixed.
https://www.2carpros.com/articles/air-vents-stay-in-the-defrost-position
Please let us know what you find.
Cheers, Ken
Jul 19, 2017 at 6:14 AM
