When the fan motor is on high it will work for a while until it starts to make a fluttering noise and air flow falls lower, then I turn it off. It sometimes will not restart, sometimes it does. I can raise the speed if I shove the snap on connection upward into the receptacle on the fan even though it is snapped in. It seems to be snapped in as far as it can be. I had the resistor replaced by a mechanic, but that hasn't changed anything. He did say it seemed to be burnt and that the fan is using excessive current. This is the original fan for I am the original owner and have not ever replaced the fan. I do not have air conditioning with this car. I possibly could tape up the connection, but I had to put some pressure upward which I doubt any tape could duplicate. Could the fan just be wearing out after 20 years?
Aug 23, 2014 at 1:49 PM
