Vent selector not working, air only blows at face
183,950 MILES • 6 CYL • 4WD • AUTOMATIC
RANDY DRYE
Replaced actuator under drivers side and checked door it moves freely, tried different control head no change.any ideas?
Sep 3, 2019 at 12:48 PM
  • 110,248 POSTS
Welcome to 2CarPros.
Are you sure you replaced the mode door actuator and not the blend air door actuator? It's a common mistake. The blend air door (mix) actuator controls temperature. The mode door actuator controls air flow directions.
I attached a picture that contains the mode actuator and the mix actuator. Take a look at the picture and let me know.
Sep 4, 2019 at 1:11 PM
RANDY DRYE
Yes, i changed the correct one.
Sep 5, 2019 at 1:58 AM
  • 110,248 POSTS
Welcome back:
The only thing left then is to confirm there is power to the actuator and it is doing its job. Have you confirmed power?
Sep 5, 2019 at 12:35 PM
RANDY DRYE
Yes, still nothing.
Sep 25, 2019 at 12:29 AM
  • 110,248 POSTS
Something has to be disconnected. If the actuator is working and not moving the door, something has broken or become disconnected.
Sep 25, 2019 at 10:46 AM
