Codes P2166, P2167,P2115 and P2116?
102,567 MILES • 3.8L • V6 • 2WD • AUTOMATIC
MALLYBOY
  • 329 POSTS
This vehicle started the issue of no throttle response after replacing the transmission, and they changed the APP Sensor, but it didn't solve the problem. Now I want to know if cleaning the Throttle Body or replacing it would solve the problem?
Sep 16, 2022 at 4:29 AM
  • 110,248 POSTS
These codes are similar. I have to ask. You indicated the APP was replaced. Did they perform the relearn procedure after it was installed? That is the one thing that is indicated for each of the codes you provided. See pic below
Let me know if this was done. Also, let me know if this started as soon as the work was done or if it took a few days.
See pic below.
Sep 16, 2022 at 2:13 PM
MALLYBOY
  • 329 POSTS
Did they perform the relearn procedure after it was installed? No
Also, let me know if this started as soon as the work was done? Yes
Sep 17, 2022 at 9:14 AM
  • 110,248 POSTS
The relearn needs to be performed. Is this something you are comfortable performing? It will require a scan tool with the ability to communicate with the different modules and program components.
Sep 17, 2022 at 2:56 PM
MALLYBOY
  • 329 POSTS
Have relearn the previous APP sensor and those codes gone, and the problem solved.
Sep 28, 2022 at 6:13 AM
  • 110,248 POSTS
Thank you for the update. I'm glad to hear you resolved the issue.
Take care and please feel free to come back anytime in the future. You are always welcome.
Sep 28, 2022 at 11:01 AM
