Vehicle will not start
229,000 MILES • 4.0L • V6 • 2WD • AUTOMATIC
JT0926
  • 5 POSTS
It was running. Checked fuses to see if any needed replacing, saw that some were correct and some weren't, so I put them all correct now it will not start. Help
May 14, 2022 at 8:49 AM
  • 110,251 POSTS
Were the fuses removed while the vehicle was running? At this point, does the starter engage when trying to start it or does nothing happen?
If it is the starter, take a look through this link. It explains how to test and repair a starter.
If the starter is working, see if it starts for a couple of seconds with starting fluid. If it does and then stalls, we know it's a fuel-related issue. If there is no change, then suspect the ignition system. Here is a link that explains how to check for spark:
https://www.2carpros.com/articles/how-to-check-for-ignition-spark
Let me know as much as you can.
May 14, 2022 at 2:39 PM
JT0926
  • 5 POSTS
No, the vehicle wasn't running.
May 14, 2022 at 11:30 PM
JT0926
  • 5 POSTS
This is what it does.
May 14, 2022 at 11:42 PM
JT0926
  • 5 POSTS
Joe, let me clarify. By checking the fuses, I pulled each one individually and inspected to see if they were blown. I may have had a few out at the same time.
May 15, 2022 at 2:25 AM
  • 55,770 POSTS
Do you have a security light flashing? If so, it will cause this issue. this guide should help you reset it:
https://www.2carpros.com/articles/how-to-reset-a-security-system
May 16, 2022 at 6:23 AM
JT0926
  • 5 POSTS
Ken L, no, the security light doesn't flash. It's lit continuously. I bought an obd1 reader but can't find the port. I've looked under the dash on the driver's side and under the hood by the ECM and all on the fire wall. Also, I know that it's "L" shaped.
May 28, 2022 at 8:39 AM
  • 55,770 POSTS
Yes, it is under the hood near the PCM here is an image of its location in the diagrams below, I have also included the code table identifications in the link below as well.
https://www.2carpros.com/articles/jeep-diagnostic-trouble-codes-for-car-built-on-or-before-1995-odb1
Check out the diagrams (below). Please let us know what you find.
May 29, 2022 at 2:40 AM
