Engine Low power
75,000 MILES • 3.0L • 4 CYL • TURBO • 4WD • AUTOMATIC
JAMES NEWALL
Hi, I had the injectors recently done and since then the car does not want to run properly. it is now under powered and when hot revs drop from 900 to 500 and then won't move or rev up. I out it into park and rev the engine a little and move it back to drive and although sluggish the car will then move and rev up. Please any help on what the problem is.
Oct 26, 2019 at 11:05 PM
  • 55,797 POSTS
This sounds like you have a clogged up exhaust system. To be sure here is a guide to help us confirm the issue:
https://www.2carpros.com/articles/how-to-test-a-catalytic-converter
and
https://www.2carpros.com/articles/engine-has-low-power-output
Oct 28, 2019 at 6:31 AM
JAMES NEWALL
I have just checked the vehicle and I don't have a catalytic converter on the car. it was removed when the power pipe was installed.
Oct 28, 2019 at 5:56 PM
  • 55,797 POSTS
Okay, lets check the turbo endplay. Remove either the intake or exhaust side to check the endplay of the turbo which will determine its wear. Here is a guide to help us see whats going on we should run the codes as well:
and
https://www.2carpros.com/articles/how-turbo-chargers-work
Oct 29, 2019 at 3:45 AM
JAMES NEWALL
The turbo has a bit of play in it and is leaking oil. So needs to be seen too. But my turbo only kicks in at 1,800 revs and the problem is at take off once the turbo kicks in it runs okay.
Oct 29, 2019 at 7:16 PM
  • 55,797 POSTS
The turbo works at all levels weather you feel the power or not. Can you please shoot a quick video with your phone so we can see what's going on with the endplay, that would be great. You can upload it here with your response. I can tell if the turbo is affecting the engine or not if I can see the endplay.
Oct 31, 2019 at 3:12 AM
