Vehicle will turn over but not start
140,000 MILES • 5.3L • V8 • 2WD • AUTOMATIC
CHH586299
The truck has no problem turning over but it will not start in the morning unless I connect my battery charger to the battery. I have replaced the battery and that did not solved the problem.
Oct 10, 2016 at 11:36 PM
HMAC300
  • 48,601 POSTS
check battery for condition including load test most places do for free. even if new they can still be bad. also, is it correct size for truck. then test for a parasitic draw.
Oct 11, 2016 at 5:08 AM
CHH586299
I will get it checked out. could it possibly be the battery cables? They are the original cables.
Oct 11, 2016 at 5:14 AM
HMAC300
  • 48,601 POSTS
It could be If you have voltage at fuse box and starter then no as long as it is battery voltage.
Oct 11, 2016 at 7:59 AM
