vehicle will not shift out of the park poisition while the van is running.
120,000 MILES
JASONHELNER
The van will not shift out of park while the van is running. also the brake lights are not working. However, if you put the van in nuetral and start it then the vehicle can be shifted into reverse and drive, but the brakelights still wont work. I have replaced the switch at the brake pedal and this did not fix the problem. I heard it may be a cable or a relay. could you please advise? Thank you
May 23, 2013 at 5:13 AM
SEANGRANT00
  • EXPERT
  • 334 POSTS
What size engine do you have?
Sean
Jul 8, 2013 at 9:28 AM
WILDMAN22
change the shift relay on your columthey r around 50 to 75 dollars
Feb 7, 2014 at 8:40 PM
