Vehicle shuts off after acceleration?
200,000 MILES • 3.5L • 6 CYL • 2WD • AUTOMATIC
OSVALDO480
Vehicle will shut off after acceleration. no check engine light or codes in scanner. car will start but if you accelerate it will shutoff.
Jul 25, 2023 at 2:16 AM
  • 110,248 POSTS
Start by checking the fuel pump pressure. If it is weak, this can happen. Also, it may not cause the check engine light to turn on because the computer may simply think it ran out of fuel.
Here is a link that explains in general how to test fuel pump pressure. You will need a fuel pressure gauge, but most parts stores will lend one to you.
If you look below, I attached the manufacturer's fuel pressure specifications.
Let me know what you find. Also, let me know if there is any smoke from the exhaust or odd odors you noticed.
joe
See pic below.
Jul 25, 2023 at 2:44 PM
