Vehicle shutting off when coming to stop or shifting down
260,000 MILES • 0.8L • 3 CYL • 2WD • MANUAL
TEAMBSI
  • 39 POSTS
I noticed it happens when I clutch too early unlike when I brake until the last minute.
I have change the following: Idling valve, TPS sensor, injector rail, MAP sensor, intake, throttle body.
Please help me!
Sep 9, 2020 at 8:56 PM
  • 110,248 POSTS
Have you checked for engine vacuum leaks? That can be a common cause. Also, is the mileage you listed correct?
Here is a link that explains how to check for leaks:
Also, when you first start the engine, will it continue to run at idle?
Sep 10, 2020 at 11:00 AM
