Vehicle switching off while driving
20,000 MILES • 1.3L • 4 CYL • 2WD • MANUAL
RISH7867
I have a cub 1300 just repaired and serviced carburetor and changed fuel pump.when driving after a while it switches of like there's no fuel but starts after awhile. any advise on what could be the problem?
May 17, 2019 at 6:05 AM
  • 110,248 POSTS
Welcome to 2CarPros.
This vehicle is not offered in the US, so my technical information is limited. However, what you have described sounds like a bad crankshaft position sensor. When it stalls and won't start, you need to check for spark to the plugs. If there is none, then suspect the sensor.
Now, and I apologize for this in advance, without having this vehicle in my manuals, I'm not 100% sure this vehicle has one, but most cars do.
Here are links you may find helpful. First, there is a link that discusses what a crank sensor does, one that describes symptoms, and one that shows in general how one is replaced. The last link I provided shows how to check for ignition spark to the plugs which I feel may be missing when the car shuts off and won't restart.
Take a look through these and let me know if they help.
https://www.2carpros.com/articles/how-a-crank-shaft-angle-sensor-works
____________________________________
How to check for spark:
Here are some general links you may find helpful when testing for spark.
May 17, 2019 at 1:55 PM
