Vehicle suddenly shut off
200,000 MILES • 3.4L • V6 • 2WD • AUTOMATIC
808USHOULDKNOW
After putting my fuse box back under my hood. Then put all fuses in the right places, I closed my hood and not two minutes later it suddenly shuts off and won't start again. I changed all six spark plugs recently. My fuel pump is hot wired to my fuse box on the driver side panel.
Dec 29, 2021 at 4:43 PM
  • 110,248 POSTS
When you say hotwired, where are you getting power from? I realize the fuse box, but do you have the pump fused? Did you check that fuse? Do you hear the pump running?
Let me know as many of the specifics as possible. Also, let me know why the pump power supply was modified.
Dec 30, 2021 at 10:19 AM
