vehicle stops running when heater is turned on?
175,000 MILES • V8 • 2WD • AUTOMATIC
NICHOLAS DOMINICK
car running turn the heat on vehicle stops, engine light comes on. The fuel pump has been replaced.
Jan 18, 2024 at 4:25 AM
  • 110,248 POSTS
This may sound crazy but check to see if the A/C compressor engages when you turn the heat on. If it is, disconnect the power supply to it and see if the engine stalls.
Jan 18, 2024 at 5:31 AM
