Vehicle starts then quits after about 2 minutes?
200,000 MILES • 2.2L • 4 CYL • 2WD
SPIDA
Aloha,
I noticed when I went to start the vehicle, it would start, then quit. At one point, I was able to get it home, about a two-mile drive.
I replaced the fuel sending unit, throttle position sensor, fuel pressure regulator, and idle air control valve.
When the vehicle does start, the idle is normal
The codes were 41 & 42.
Mahalo,
Rich
Apr 14, 2026 at 8:22 AM
  • 55,588 POSTS
Hello from the mainland!
Code 41 - Throttle Position Sensor signal
Code 42 - Vehicle Speed Sensor signal
So code 41 is the one that will cause the starting and stalling. So please recheck the work on that part, also I would check for vacuum leaks, this video will help.
https://www.youtube.com/watch?v=LRKWV4Are5c
I would clean the throttle body and IAC passages. Please go over these 2 guides as well.
and
https://www.2carpros.com/articles/stall-at-idle
Please upload a short video in your response of the problem, so I can see what's going on. Please go over these guides and get back to us. Ken
Apr 15, 2026 at 12:52 AM
SPIDA
I replaced the ECU and now my 1992 Camry is back on the the road. Mahalo for your help.
May 2, 2026 at 6:42 PM
  • 55,588 POSTS
Good to hear, please use 2CarPros anytime we are here to help.
May 2, 2026 at 6:43 PM
