Vehicle stalls/shuts off when coming to a stop. Code is P0300 has back fired once.
Mar 2, 2018 at 9:31 AM
✓Experienced Mechanic
Good evening.
I would check the fuel pressure. you may have a bad fuel pump.
Also, you may be losing spark as well.
Check the fuel pressure first. there is an access port on the fuel rail back by the distributor. you can rent a tester at a parts store if you do not have one.
Mar 2, 2018 at 9:54 AM
RYAN L
Hello GAIL1954,
Here is a link to an informative article with step by step written instructions and pictures on how to test fuel pressure:
If you need any further help please come back to this post. We are always happy to help.
Thank you for visiting 2CarPros.
Kindest regards,
Ryan
Admin
Mar 3, 2018 at 5:11 AM
GAIL1954
MEMBER
The check engine light is now flashing on and off. It is not staying on just flashing on then off.
Mar 3, 2018 at 8:22 AM
That indicates a misfire in one or more cylinders. It could be plugs, wires, cap or rotor.
How long since a good tune up?
Mar 3, 2018 at 8:38 AM
GAIL1954
MEMBER
Just got it from a used car lot.
Mar 3, 2018 at 12:56 PM
I would start by checking the plugs and all filters. it could be basic ignition issues such as plugs, wires, cap and rotor.
Mar 3, 2018 at 8:36 PM
