Vehicle speed sensor location
132,000 MILES • 3.6L • V6 • 2WD • AUTOMATIC
2009 G6 GXP
I was stuck in the snow and I turned off my traction to spin wheels and now my car doesn’t shift right, runs really rough. my check engine light came on for vehicle speed sensor. it was running fine before this. I can’t seem to find where the VSS is located on my car. Please help!
Feb 16, 2019 at 9:15 PM
Good evening,
It sounds like you may have damaged the transmission.
What is the exact code?
Let's start with the code.
Feb 17, 2019 at 9:07 AM
2009 G6 GXP
The code came up for vehicle speed sensor and I cant find it on the car.
Feb 17, 2019 at 6:53 PM
Again, what is the code number? I need the number as there are several codes for this sensor.
The sensor is under the car where the right front axle comes out of the transmission.
Feb 17, 2019 at 7:36 PM
2009 G6 GXP
I have a 3.6.
Feb 17, 2019 at 11:05 PM
I saw that.
I still need the code number that led you to think the sensor is bad.
Feb 17, 2019 at 11:07 PM
