Where is the vehicle speed sensor located?
200,000 MILES • 1.6L • 4 CYL • 2WD • AUTOMATIC
PRINZKENNY
Can you help me locate the vehicle speed sensor?
Jun 3, 2024 at 12:06 AM
BORIS K
  • 836 POSTS
The vehicle speed sensor is located on the transmission housing, see item 2 on image.
I suggest checking the 3-pin connector, ensuring it is fitted correctly and that there are no broken wires or corrosion.
Cheers, Boris
Jun 3, 2024 at 8:13 PM
PRINZKENNY
I just checked, I can't locate the VSS on the 307 gearbox. Its rather the 206 the has the VSS fitted on the gearbox.
Jun 4, 2024 at 8:50 AM
