Vehicle overheats when in park
120,000 MILES
JOE PFLANZ
Will cook back down when in drive. What would cause this?
Aug 30, 2019 at 9:59 AM
Good evening.
Is the engine cooling fan working drawing air through the radiator?
https://www.2carpros.com/articles/replace-electric-fan-motor
https://www.2carpros.com/articles/how-a-clutch-fan-works
Aug 30, 2019 at 10:39 AM
JOE PFLANZ
Yes the fan rotates freely when car is off with no key in ignition. When car is started the fan does run.
Aug 31, 2019 at 11:31 AM
If t is not turning fast enough, it will cause this. It is a fan clutch that may be worn out and not locking in to pull through the air.
Aug 31, 2019 at 12:01 PM
