This vehicle does not raise above 3,200RPMs at wide open throttle. when i diagnosed the instrument cluster and transmission using garage pro app and obdlink scanner, it recorded code p2120 only without description and on transmission it recorded p1775.
I used Autel scanner Maxispro to diagnose it again and it recorded description without fault code: "improper power down detected".
And while accelerating the vehicle, if you throttle on second gear to move faster and shift into third gear, it will begin to drag and will not shift until you release pedal and depress it slightly before it shifts upward gear
At this point i don't know how to analyze and solve the problem.
Jan 7, 2022 at 7:52 PM
