Vehicle overheating I added coolant. thermostat is stuck?
992,000 MILES • AUTOMATIC
TROUBLED VEHICLE
I added coolant. If just thermostat is stuck, would it be wise to first get it replaced? Can a mechanic tell if it is stuck?
Jul 6, 2018 at 10:05 AM
We should do two things to check this. First we need pressure test the system to make sure there are no leaks. Here is a guide that will show how to do this.
https://www.2carpros.com/articles/radiator-pressure-test
The next thing we need to do is use a laser temp gauge to find out if we have higher temp before the thermostat then after. If you do then the thermostat is stuck closed and it does need to be replaced.
https://www.2carpros.com/articles/how-to-use-an-infrared-temperature-meter
If this is what you find then here is a guide that will help with this.
I would not let this go because the engine is going to continue to overheat and eventually it will cause a head gasket issue or worse.
So let us know what you find with this and we can go from there. Thanks
Dec 18, 2021 at 9:11 AM
