If the vehicle is hot it does not accelerate as it should and is white smoking in the process
May 23, 2014 at 10:49 PM
WRENCHTECH
✓Experienced Mechanic
That is generally the symptom of burning coolant in the combustion chamber and the sign of a blown head gasket. I would have it tested for a head gasket.
May 23, 2014 at 11:52 PM
MAYERSJ
MEMBER
Thanks for the quick reply will have the head gasket checked out and keep you posted if that works.
