Vehicle is overcharging
67,000 MILES • 3.0L • 6 CYL • 2WD • AUTOMATIC
AUSTINO
  • 231 POSTS
Good afternoon, my vehicle is overcharging.Do you know what can cause this to happen?Thank you in advance.
Jun 28, 2020 at 3:07 AM
When you say it is overcharging, what is the actual voltage it is charging when the engine is running?
Take a look at this information. The ECM will target 14-15 volts and will back it down to 13.6 volts when needed. Let's start with what the voltage is and go from there. Thanks
Jun 28, 2020 at 9:49 AM
AUSTINO
  • 231 POSTS
Thank you for that information. yes, it is over charging when the engine is running and also the acid from the battery is leaking out.
Jun 29, 2020 at 12:20 AM
Okay. Clearly we need to replace the battery but again, we need to find out the exact voltage it is charging. There is a chance that the PCM is trying to raise the voltage due to the battery so I would replace the battery due to the leaking and retest the alternator output.
Here is a guide on how to test the alternator:
Jun 29, 2020 at 1:03 PM
AUSTINO
  • 231 POSTS
Thank you so much. you're so helpful.
Jun 29, 2020 at 10:42 PM
Thank you. You are very welcome. Please let us know what happens or if you need more help. Thanks
Jun 30, 2020 at 11:31 AM
AUSTINO
  • 231 POSTS
Thank you, I will.
Jul 1, 2020 at 7:48 AM
