Vehicle information center
178,550 MILES • 5.2L • V8 • 4WD • AUTOMATIC
BRETTK
How do you test just the vehicle information center to see if it works by itself, or is it possible?
Jan 28, 2019 at 7:25 PM
Good morning,
No, not something you can do. That is controlled by a module.
DIAGNOSIS AND TESTING
The Vehicle Information Center (VIC) has a number of display functions and features. The diagnosis found here addresses only those VIC messages and functions that are controlled by hard wired inputs. To diagnose any internally controlled VIC function or feature, or any that are enabled by inputs on the CCD data bus network, use a DRB scan tool and the proper Computers and Control Systems/Body Control Module/Testing and Inspection Procedures.
What is the issue that makes you ask this question?
Jan 28, 2019 at 7:52 PM
BRETTK
Mine is not turning on but everything else does in my vehicle Limited Orvis Edition.
Jan 29, 2019 at 2:18 AM
Got it but it needs to be checked with the scan tool. It may be a bad center.
Jan 29, 2019 at 6:32 AM
