Vehicle identification?
242,000 MILES • 3.4L • 6 CYL • 4WD • MANUAL
NAINOA
  • 41 POSTS
I noticed these numbers while I was replacing an alternator and on the bracket and the block I noticed some numbers I was wondering if these numbers are the VIN or something else. Here’s a couple pictures of the numbers.
Aug 3, 2023 at 10:24 AM
  • 110,248 POSTS
Those aren't the VIN. One appears to be an engine code and the other a part number.
Where were they found?
Aug 3, 2023 at 4:13 PM
NAINOA
  • 41 POSTS
It’s behind the alternator ones on the a bracket and the other is on the block same area.
Aug 3, 2023 at 4:34 PM
NAINOA
  • 41 POSTS
By any chance is there a VIN on the engine block?
Aug 3, 2023 at 4:35 PM
  • 110,248 POSTS
The VIN is at the base of the dash/windshield on the driver's side and is usually printed on a manufacturer's label either on the door frame or under the hood.
Aug 4, 2023 at 1:02 PM
NAINOA
  • 41 POSTS
Found that it’s the engine serial number.
Aug 4, 2023 at 6:05 PM
