Low engine power
190,000 MILES • 4 CYL • AUTOMATIC
FAINSTEVE
My car is an automatic car and as usual I do engage the drive, step on the gas and it starts moving as I step on the gas. Now for the last four days that has not been the case because when I step on the gas, it takes a while before it starts moving. When I step on the gas pedal harder, it starts moving slowly and when I reach a speed of about 60 to 70 km/hr it becomes okay and moves just fine. When I slow down the problem comes back. I again have to step on the gas pedal harder for it to start moving slowly. In short, it does not have the power to make it move. The engine and the gearbox are both working just fine. What could be the problem?
Dec 12, 2018 at 3:10 AM
  • 55,722 POSTS
It sounds like you may have a clogged catalytic converter but to be sure lets run down this guide.
https://www.2carpros.com/articles/how-to-test-a-catalytic-converter
This guide can help as well.
https://www.2carpros.com/articles/engine-has-low-power-output
Cheers, Ken
Dec 14, 2018 at 4:07 AM
