Vehicle does not move right away when shifted to drive and accelerator floored?
50,000 MILES • V6 • 2WD • AUTOMATIC
ABRAM BUTLER
  • 14 POSTS
We tried to check the level and condition of the transmission fluid. Seems that there is no visible dipstick and there is a slight dent on the transmission base pan. Guidance please.
Jan 22, 2023 at 8:58 PM
  • 55,694 POSTS
The dent on the transmission pan could be causing the problem because it will block the filter from picking up fluid, this generic guide can help you as well:
https://www.2carpros.com/articles/how-to-check-and-add-transmission-fluid
The transmission should have a plug in the side of the case which can be filled much like a manual transmission would. Please let me know what you find.
Jan 23, 2023 at 2:37 AM
