Hello, I am working on a Nissan car. The owner just change the car battery last week after three days the battery was unable to power the vehicle. She brought it to workshop, after replacing the battery, I checked the voltage with the engine running, the voltage measured was 12.7v. I decided to replace the alternator and the belt but there is no change. When the engine is running,I removed one of the battery terminals the engine didn't shut down that is the alternator can power the vehicle accessories but not enough to charge battery. Putting new battery, engine will run properly as if everything is all right but it will drain the battery gradually. What could be the cause?
The alternator is shown below
Aug 29, 2020 at 3:54 AM
