Vehicle will accelerate and decelerate on its own and high fuel consumption
1,968 MILES • 4 CYL • 2WD • AUTOMATIC
EUGINIA THOMAS-COLE
Vehicles the above even when it on park, the tachometer keeps increasing and decreasing giving a sharp sound. Consume high fuel like 30 liters within 3 days.
Nov 9, 2021 at 5:35 PM
BORIS K
  • 836 POSTS
To enable us to assist you further please have the vehicle scanned for any possible fault codes which could help us diagnose the problem.
How to scan.
Once scanned please post any fault codes here so that we can assist further.
Please let us know how you get along.
Cheers, Boris
Nov 9, 2021 at 7:05 PM
EUGINIA THOMAS-COLE
P2646
P1078
Nov 9, 2021 at 8:56 PM
MASTER ASE TECH
  • 82 POSTS
Hi, I'm Dan.
The first Code P2646 has to do with the VTEC system being stuck off. The leading cause of this failure is the engine oil level being low or dirty. The first step is to clear the code, change the oil and drive it to see if it returns.
The second one is the P1078. This usually points to the little motor that activates the intake flapper doors on the intake manifold. I've attached the diagnosis procedure for that below. You need to remove the motor, see if the intake flaps move freely, and also see if the motor moves.
Nov 11, 2021 at 4:20 AM
