VDC off light showing
2007 HYUNDAI SANTA FE
80,000 MILES • 2.2L • 4 CYL • TURBO • 4WD • AUTOMATIC
MUHAGIR
The "VDC OFF" came on in my dash board after I changed three new wheels on my car. The forth wheel is still old. I have also balanced the car.
How do I make the "VDC OFF" turn off again?
Nov 25, 2013 at 3:03 PM
  • 110,244 POSTS
Have you by chance damaged any of the wheel sensors for the ABS or stability control?
Nov 25, 2013 at 10:05 PM
MUHAGIR
i don't know if the wheel sensors for the ABS or stability control is damage or not
Nov 26, 2013 at 1:57 PM
  • 110,244 POSTS
I would scan the computer to see if there are trouble codes that would indicate where the problem is coming from. That way, if it is a sensor, you will know which one.
Nov 26, 2013 at 10:19 PM
