Don't know these engines but any induction leak will be treated the same way, ensure that you locate the leak, spray a little starter fluid and if you hit the leak the rev's will increase, normally a inlet gasket, if so, replace and ensure that all traces of the old gasket are removed from the head and the manifold.
Mark (mhpautos)
SPONSORED LINKS
Friday, May 28th, 2010 AT 6:29 AM
