2005 Vauxhall Zafira oil change
BARRY FIRMIN
Engine Mechanical problem
2005 Vauxhall Zafira Manual
I have changed the oil and filter on a Zafira Diesel but when I tried to check the dip stick I find there is no oil on it I know there is 4 litres of oil in the engine please help
Apr 12, 2009 at 8:49 AM
DAVE H
  • 13,383 POSTS
Is the vehicle on level ground ? keep adding a little more oil untill you see it showing on the dipstick ... I do not have the spec's for this vehicle but it should hold around 5 litre's ... if you have the dipstick in correctly it should be showing soon ... your local library or autoparts store should be able to supply a repair manual with all the information you require !!
https://images.2carpros.com/forum/automotive_pictures/266999_AAA2_488.png
Apr 12, 2009 at 11:08 PM
OPEL PARTS GREECE
  • 131 POSTS
5 litters engine oil capacity
Apr 14, 2009 at 6:16 AM
