2003 Vauxhall Zafira rear brakes
2003 VAUXHALL ZAFIRA
BLUEPORSCHE
Brakes problem
2003 Vauxhall Zafira 4 cyl Front Wheel Drive Manual
How do I remove the hub from my 53 Zafira, got the wheel off and cannot remove the hub so I can change the brake shoes, do you need a special tool
Jan 19, 2010 at 5:28 AM
DAVE H
  • 13,384 POSTS
tap all around hub/drum with a hammer .. use 2 good size flat head screwdrivers to pry off drum from rear.. only the pressure of the shoes is holding it on
Jan 20, 2010 at 6:45 PM
